Cor: Black/Grey/Rose Golden
Dimensões: 148.2 X 72.8 X 9.5 mm
Peso: 170g (with battery)
Sistema Operativo: Android 6.0 Marshmallow
CPU: MT6737 processor Quad-core 1.3GHz CPU
RAM: 2GB RAM
ROM: 16GB (SD card Up to 128GB)
Bateria: SONY 3500mAh Li-Polymer Battery
Standby Time: 360h
Ecrã
Tamanho: 5.0 polegadas
Resolução: HD 1280*720 pixeiss
Corning® Gorilla® Glass 3
Cameras
Camera traseira de 8.0 MP (Interpolated to 13MP)
Camera frontal de 5.0 MP
Photoflash Flash
Conectividade
2G:
GSM: 850/900/1800/1900 (band5,band8,band3,band2)
3G:
WCDMA: 900/2100 (band8,band1)
4G:
FDD-LTE: 800/900/1800/2100/2600 (band20,band8,band3,band1,band7)
SIM Dual sim dual standby, Dual Micro SIM
Both SIM slots are compatible with 4G, respectively. When they work at the same time, only one of them can receive LTE service and the other GSM. You can choose in settings which one for 4G.
TF-Card 128GB
WiFi 2.4GHz/5GHz 802.11ab/g/n.
Bluetooth Bluetooth 4.0
Positioning GPS/Glonass
Gravity Sensor
Touch Sensor, OTG
Functions FM
Language Indonesian, Malay, Catalan, Czech, Danish, German, Estonian, English, Spanish, Filipino, French, Croatian, Italian, Latvian, Lithuanian, Hungarian, Dutch, Norwegian, Polish, Portuguese, Romanian, Slovak, Finnish, Swedish, Vietnamese, Greek, Turkish, Bulgarian, Russian, Serb, Ukrainian, Armenian, Hebrew, Urdu, Arabic, Persian, Hindi, Bengali, Thai, Korean, Burmese, Japanese, Simplified Chinese, Traditional Chinese
Embalagem
U008 Pro Phone x 1
Charger x 1
USB Cable x 1
Multiple Languages Manual x 1
http://ulefone.com/p...o/features.html
