A Oukitel confirmou as especificações para o seu novo K6000 Pro.
O K6000 Pro é basicamente uma actiualização do anterior K6000, que se tornou um best seller da marca
Especificações do Oukitel K6000 Pro:
Color: White/Grey
Dimensions: 10×76.7×154.3 mm
Weight: 213.88g (Build-in Battery)
Operating System: Android 6.0
Fingerprint ID: unlock in 0.3 second
CPU: 64 bit octa-core MT6753
GPU: Mali-T720 GPU
RAM: 3GB LPDDR3
ROM: 32GB, TF card support up to 32GB
Battery: SCUD 6000mAh Lithium Polymer
Talk time: 46 hours
Music: 45 hours
Videos: 10 hours
Charger: MTK Pump Express Flash Charging 5V/7V/9V-2A Intelligent flash charge
Resolution: FHD 1920×1080 pixels
Type: LTPS 2.5D
Material: AGC Dragontrail 2 Glass
Rear camera: 13MP, Front camera: 5MP
Rear camera: 16MP(Interpolated)
Front camera: 8MP(Interpolated)
F2.0 Aperture, Dual Flash
Video: 1080P
SIM: Dual SIM dual standby
Wifi: Support
Bluetooth: Bluetooth 4.0
Positioning: GPS, A-GPS, GLONASS
Sensors: G-sensor, Light sensor, Proximity sensor, Hall Effect sensor
Functions: FM radio, OTG, Hotknot, Miracast, Off-screen gesture, Super power saving mode
Testes de qualidade:
