Meus caros
Deparei-me com um módulo do Xposed que parece ser o que há muito procurávamos, tipo canivete suiço, concentra imensas ferramentas numa única app. E estou-me a referir à versão free.
Ainda estou a ver o que isto dá, mas já percebi que algumas app podem ser desinstaladas por conta desta, preciso apenas de estar seguro com a estabilidade e rigor do output.
Agradeço ajuda de todos a explorar estas funcionalidades ( ou ver se as vantagens estão exageradas)
Para Xposed e com Root, para tirar todas as vantagens
♦ Feature set (some require root access, try free version first) ♦♦
► Device manager *
◊ Device profiles (CPU, IO, components)
◊ Tasks scheduler (app management, clean-up, etc)
◊ Device watchers to automatically activate a profile, run tasks or display alarms
◊ Battery savings using profiles and tasks
► File explorer *
◊ Batch copy/paste, zip, delete, move, share and stream files and folders
◊ Change files/folders permissions and ownership
◊ Access all your Samba network shares
► Application manager *
◊ Backup app apk/data (multiple versions), sms and call-logs
◊ System app uninstaller and update cleaner
◊ Share (email, bluetooth, dropbox, google drive, etc)
◊ Move any apps to user, system, SD or link2SD
◊ Freeze/unfreeze apps, crystallize (greenify/hibernate) control app startup and events
◊ Zip align, clear cache, wipe dalvik-cache, fix permissions and optimize databases
◊ Control app permissions, locker (secure access), rotation and force screen-on **
◊ Notification disabler on JB+
◊ Usage and standby statistics (find app draining your battery)
► Network manager
◊ Set WiFi access point priority
◊ Configure Android firewall *
◊ TCP Congestion control *
◊ DNS Changer *
► Task manager
◊ Check CPU, network and memory usage
◊ Kill (default) or force-stop * any apps or kernel processes
◊ Automatic task killer, memory booster, memory cleaner
► System Control *
◊ CPU governor, frequency, voltage, GPU controls, thermal and MPDecision controls
◊ Build.prop and sysctl editor (basic and advanced mode)
◊ Boost, analyze and benchmark SD cards
◊ Android memory manager, memory cleaner, SD linker (directory binder)
◊ fsync, sweep2wake, gamma and fast charge control
◊ Safe: restore defaults from app or recovery and CPU settings on boot-loop
► System Monitoring
◊ All Android applications or all processes, battery, CPU, network, memory
◊ Component states (WiFi, Bluetooth, GPS, 3G, Phone, APN)
► Status bar notifications *
◊ Battery, cpu, memory, sd, temperature optionally with graphics in drop-down
◊ Add battery remaining bar on top or bottom
◊ Remove original battery icon
► Highly Configurable Widgets
◊ Resizable gauge widget
◊ 1x1 and 2x1 (PRO ONLY) text widgets
◊ 2x1-5x2 graphic widgets (PRO ONLY)
◊ 1x1 and 4x1-1x4 (PRO ONLY) toggle widgets *
◊ 4x4 summary widget (PRO ONLY)
► System Toggles (manual widgets or in profiles)
◊ GPS, WiFi localization
◊ WiFi, BT, BT discoverable, APN, NFC, airplane
◊ Tethering (USB, WiFi, BT)
◊ Brightness, screen time-out, stay awake, flashlight
◊ Ringer, vibrate, synchro, background data
◊ Debug (over WiFi), unknown sources, USB storage, reboot
► Terminal Emulator & Script Editor
◊ Command history
◊ Run or test any scripts, optionally on boot
◊ Share scripts, commands and outputs
► System Logs Reader *
◊ Logcat reader
◊ Kernel messages (dmsg, kmsg)
◊ Advanced filtering and search
► And much more...
LinK: Android Tuner
