Model: GT-N7100
Country: Open Asia
Version: Android 4.3
Changelist: 1903221
Build date: Wed, 16 Oct 2013 23:49:26 +0000
Product Code: OLB
PDA: N7100XXUEMJ5
CSC: N7100OLBEMJ4
MODEM: N7100XXUEMJ5
Download: N7100XXUEMJ5_N7100OLBEMJ4_N7100XXUEMJ5_OLB.zip
NOTE
- This test firmware will NOT increase your binary counter NOR void your warranty.
- This test firmware is a pre-release firmware and not official from Samsung.
INSTRUCTIONS
- Extract (unzip) the firmware file
- Download Odin3 v3.09 (From here or here)
- Extract Odin .ZIP file
- Open Odin3 v3.09
- Restart phone in download mode (Press and hold Home + Power + Volume down buttons)
- Connect phone and wait until you get a blue sign in Odin
- Add N7100XXUEMJ5_N7100OLBEMJ4_N7100XXUEMJ5_HOME.tar.md5 to AP
- Make sure re-partition is NOT ticked
- Click start button, sit back and wait a few minutes.
- If you encounter any issues with the firmware (Any FC, Bootloop etc)
- Boot into recovery mode (Home+power+vol up)
- Choose to wipe/factory reset. (THIS WILL ERASE ALL OF YOUR DATA INCLUDING YOUR INTERNAL SD CARD!)
- Then choose reboot and you should be good to go!
