Roms da Jellaxy Estas Nightly´s são mais estáveis
CyanogenMod 10
- cm-10-20120917-UNOFFICIAL-gio.zip (1417)
- cm-10-20120915-UNOFFICIAL-gio.zip (1478)
- cm-10-20120912-UNOFFICIAL-gio (1399)
- cm-10-20120907-UNOFFICIAL-gio.zip (1744)
- cm-10-20120907-UNOFFICIAL-gio-no-a2sd.zip (752) (no a2sd script, use if you have no ext partition on your SD)
- cm-10-20120903-UNOFFICIAL-gio.zip (686)
- cm-10-20120831-UNOFFICIAL-gio.zip (43)
- cm-10-20120827-UNOFFICIAL-gio.zip (63)
HQ playback (need hardware drivers for that which are NOT available)
Native Wifi Tethering
Native USB Thethering
Network usage
Videorecording & panorama
Rom AOKP E uma rom Jelly Bean sem mudanças
Roms Maclaw
- CyanogenMod 10 (based on Android 4.1.1)
- Galaxy Gio beta1
- Galaxy Gio Beta2 change log
CM10:
- adb working
- better battery life, also really cold battery
- new CM10 bootanim
- updated cm10 sources
- no more black screen when booting – bootlogo is back
- CM settings are fully merged
- camera is working (except video recording, but everything else is working) – in all apps!
- fixed sensors
- new kernel (2.6.35.14, partially based on Squadzone kernel)
- kernel: linaro optimized
- kernel: pure JB ramdisk without any modifications
- Superuser is fixed
- bluetooth is now working at all, without any bugs
- deep sleep is working when you’re leaving camera (no reboots needed)
- voice search is working
- Google Now is working
- Galaxy Gio beta1
- Galaxy Gio RC1
- Galaxy Gio RC2
Gio/Ace SU fix:apply this patch after installing rc2 ( apply patch useing clockwork mod recovery )
SU patch
Mount system before installation. - ChangelogCM9.1 RC2
- Deep sleep is working when you’re leaving camera (no reboots needed)
- kernel: pure ICS ramdisk without any modifications
- bootlogo is back
- updated cm sources
Editado por Bostonextremeist, 21 September 2012 - 09:22.
