Here is a new release of your favorite Cronos ROM for your Device. This time it has the first release of Cronos X included. This is still WIP (Work In Progress) by me and Computerfreak so please dont go flaming us about features that are not included. If you have a wish list of functions please use a proper Forum thread to post them so that we can have a look at it. NOTE: DOES THE PHONE FEEL SLOW AFTER THE FIRST FLASH? GO TO X SETTINGS, CPU SETTINGS AND CHANGE THE MINIMUM AND MAXIMUM SPEED TO YOUR DESIRED SPEED. I HAVE HAD TO PUT A LOWISH DEFAULT THAT IS SAFE FOR EVERY DEVICE.
Release notes: 25 July 2011 | Cronos Ginger X 1.0.1: Fixed: Android Battery Drain. Please recalibrate your battery. Please fully charge the battery to 100%. X Settings updated to version 0.0.3 Font sizing will stay permanent. Fixed: ScreenStatus Scaling. Fixed 30tweak file, thanks bleep42. System should be a bit snappier. Added a new version string for X Settings Mod itself. Volume rocker wakeup port by ComputerFreak Enable/disable CRT on/off animationport by Feeyo/Computerfreak Added option to change the indicator color in the notification widget port by ComputerFreak Fixed some checkboxed incorrectly checked by default by ComputerFreak Fixed some incorrect text when selecting brightness mode by ComputerFreak First release of Cronos X. Settings have extended options. Font size options ported by ComputerFreak. Battery Percentage option added. Battery Percentage Bug, fixed by ComputerFreak. widget button FC on MDPI devices fixed by ComputeFreak. Improved Danish Translations by ComputerFreak. Extra animation option ported by ComputerFreak. small GUI changes by ComputerFreak. A few tweaks used with flags. Fully Removed CM Extra. Sources have been updated to latest AOSP. Source for external and hardware support updated to latest CM. libSqlite improvement. Added Call Delay tweak by jyxent. lowmemorykiller improvement (Again) Added a few tweaks from Juwe11. BatteryWipe on flash by Seo. And of course all the Cronos speed imrpovements Added.Download CGXSNS-1.0.1: http://cronos.bertol...XSNS-1.0.1_.zip MD5SUM On the download link system. Google APPS: Download latest gapps: The Official Cronos Android Mirror
