CyanogenMod Installer
Welcome to the CyanogenMod Installer! This easy-to-use app lets you load
CyanogenMod onto your device.
Advanced Users - Looking for more specific resources? Check out the
download page and search for your device.
1
Allow installation of the CyanogenMod Installer App
Open the Settings application and navigate to Security.
(on some devices, you may need to navigate to Applications)
Locate the Unknown sources option.
If Unknown sources is already checked, you can skip this step.
If unchecked, tap the checkbox and then tap OK on the
confirmation popup.
2
Download the CyanogenMod Installer App
From your Android phone or tablet, visit
using your web browser or scan the QR code.
3
Install the CyanogenMod Installer App
When the download is complete, open your notifications and tap
OneClick.apk.
Tap Install to start the installation.
Once it's finished, tap Open to run the app.
Follow the instructions displayed on your Android phone or tablet to
continue the installation process.
4 Download the CyanogenMod Windows Installer
Download the CyanogenMod Installer for Windows Vista/7/8.
Run the CyanogenMod Installer for Windows and follow the on-screen
instructions.
5 Enjoy CM!
ESPERO TER AJUDADO
Editado por timelo, 15 March 2014 - 12:10.
